The camera firmware should be up-to-date, but I would still log in to each and check.
As you have the (C) models the latest firmware should be v5
Does this list go top to bottom or bottom to top?The camera firmware should be up-to-date, but I would still log in to each and check.
As you have the (C) models the latest firmware should be v5.7.2
I would use the UK site for camera firmware. Just pointed towards the EU portal for the older NVR firmwareDoes this list go top to bottom or bottom to top?
I'm very confused
Current firmware on cameras is V.5.5.801, what do I need?
Try to add your update in here as well as users can then use the links for the firmware locations etcDS-7608NI-I2 v4.60.000 update. Causing green screen issue. Whos had it?
Thought I would see if any one has had issues with the v4.60.000 update affecting the 8mp hd viewing in hik connect? I had my ds-7608ni-i2 updated a month ago before I got my 8mp installed. Straight away I had issues trying to view it in HD via the app. I got a green screen. Looking all over...www.use-ip.co.uk
I used the europe site for my cameras and NVR firmware. Just seen the new firmware whilst at work so can’t test it yetIs it ok to use the Europe one?
If you download it and it fixes your issue let me know.I used the europe site for my cameras and NVR firmware. Just seen the new firmware whilst at work so can’t test it yet
Will try it this evening. Has yours defo improved with the older version?If you download it and it fixes your issue let me know.
