Hi. I have just spent the best part of yesterday trying to add 3rd party cameras to a new DS-7732NI-M4/24P without success and after reading threads on here I assume this must be to do with the v5 firmware this NVR has installed.
I run 2 cctv systems each with an NVR and 20 cameras attached via POE. They were originally Aspect NVRs and cameras but am slowly replacing the cameras with Hikvision ones and replaced one of the NVRs with a DS-7604NXI-K1/4P earlier this year. The NVR located the cameras that I added one by one using the manual function via Onvif.
I thought it would be pretty straightforward to set up the new NVR in the same way but cannot find the manual function on the configuration and it only seems to offer plug and play, which works fine with the 2 Hik cameras but will not connect the Aspect cameras. It can see the cameras but won't connect..
Could anyone offer advice regarding a different way I can link these cameras or methods they have used that have worked? There are options for RTSP and DHCP but not sure what this means of whether these should be enabled?
Any help would be greatly appreciated
