Request: Custom Firmware for DS-7208HQHI-K1 with USB Wi-Fi Support
abdennour
Hi, I have a DS-7208HQHI-K1 DVR (possibly Chinese version) and need a firmware that supports USB Wi-Fi. The official firmware doesn't support it. If anyone has a working version or a download link, please share. Thanks!
Why not just connect the DVR to a WiFi bridge and set the bridge to client mode. Much easier and probably better WiFi performance than a USB dongle. The below works perfectly well for this:
Amazon - TP-Link Travel Router
It used to work fine before, so I'm currently looking for firmware that supports the WiFi dongle feature again.
Most likely, the DVR either lost this support after a firmware update, or the settings were reset and removed the working configuration. So I'm trying to find a firmware version that re-enables WiFi support.
It's an old discontinued model so unfortunately if there's no customised version available now in the portal (I cannot find one), then it's not available.
If that was the case, the tab in the local UI for WiFi would no longer be visible. Without a customised version from Hikvision, your only option (other than an adapter) would be to downgrade the firmware to the previous version that supports it.
So the tab in the local UI would still be there and you could re-scan and re-select your WiFi network.
I wouldn't downgrade firmware for the sake of buying a £20 dongle.
