Hello
Got me a Hikvision DS-7608NI-I2 and after some trial and errors it now works fine with two Hikvision cameras. Real problems began with an Unifi UVC G3 cam wich I want to add, and now I'm stuck.
First of all the G3 doesn't have ONVIF but according to forum posts that shouldn't be nessecary. I set the camera in standalone mode, modify the IP to the subnet of the Hikvision NVR, turn it to static IP and move it to one of the NVR ports after restart.
NVR port is changed to actual IP. A new protocol is set up with RTSP stream "rtsp://192.168.1.254/s2" (wich worked on VLC on the ordinariy network). Have tried UDP, RTP over UDP and auto but nothing work and I now begin to get out of ideas of what to try more.
I find two things a little peculiar: management port is 0 and can't be changed and it seems user and password resets after every failure to include the camera. On the other side I didn't think there should be a control port when just catching the stream?
Are there anyone out there who have found out how to succeed with this?
