FAQ Can an AXIS Camera be Connected to My Hikvision NVR?
JulioFr1ch
Hello everyone, I was able to recover an Axis camera, do you know if it is possible to connect it to a Hikvision NVR?
You would have to check the model number of camera and download the data sheet from Axis. If it supports ONVIF you should be able to connect it to a Hikvision NVR.
Hi @JulioFr1ch
@JB1970 is correct that if the model is ONVIF compliant you should be able to add it to the NVR as an ONVIF camera.
The forum guide below should help you with how to add it (it is for a brand called Optio, but just replace the word Optio with AXIS and the process is very similar)
