Can't get the Microphone on my DS-2CD2347G1-LU to Work
Status
Not open for further replies.
Hi @Jaso912
Check the steps in the below forum thread
Hi @Jaso912
How do I log into the camera is it in the dvr or do I go I though another way cheers
Ok, you can access directly connected cameras on that NVR by enabling Virtual Host which creates a link to login directly to each camera.
If the camera was activated out of the box by directly connecting it to the NVR then it should be using the same password as the NVR.
It's asking for a user name and password where is this
Sorry, what do you mean "It's not creating a log in"?
Do you mean it is not accepting the password?
Can you share a screenshot of the login page that the virtual host link takes you to, including the address bar with the cameras IP address?
Just takes me to here
Take me here
I have this page too but whats the username and password
Ok, those initial screenshots are only the instructions to set up virtual host, you need to login to your NVR with a browser and follow the steps in that guide to enable the virtual host links for your directly connected cameras.
Is that the login page for the NVR or the directly connected cameras? If you are unsure can you please copy the IP address from the browser address bar and paste it into a response here.
How do you log into
Open a browser (Internet Explorer works best), enter the IP address displayed in SADP (192.168.0.16), and then enter the username and password you set the NVR up with when you first installed it. If you don't know this password you will need to contact your original seller/installer to get them to process a password reset for you.
Don't no the username as I did not set it up where can I find this
Hi thank you finally found the username and password what the put on. I got into the settings and managed to turn on the microphone thanks for all your help cheers jason
Status
