Hello hobby friends,
I braced a DS-7732ni-i4/24p NVR at a bankruptcy auction
but I don't have a password, so it needs to be reset.
I see in SAPD and in IVMS4200 that he is active in the range 10.29.76.30
And my router has the range of 192.168.2.1.
How can I reflash it and put a new firmware on it.
There are several possibilities
1. If you want to submit a password reset request, it is highly recommended that you scan the QR code to download the Hik-Partner Pro app and then submit a request.
2, If you can't make the phone on which the Hik-Partner Pro app and Hikvision device are installed on the same LAN, please click here to reset the password as shown in the video 4 Ways to Free You from Resetting Your Password
If your device does not support password reset, we strongly recommend that you click here to get instructions via computer and reply to us with the xml file and label image. Do not restart your device or re-export the xml file until you receive our reply.
3, For disconnecting from Hik-Connect, we strongly recommend that you click here Note: Available features may vary depending on the country or region.
4, For searching for firmware updates of the device, we cordially invite you to click on the following link: How to Use Firmware Update Search on Hik-Partner Pro Note: Available features may vary depending on the country or region.
5, with TFTP server and serial cable or are there other tips
Everything is welcome.
Greetings hans
Greetings hans
