Nissar
- Messages
- 9
- Points
- 1
Dear all,
I am so happy to have found such a resourceful site.
I am really getting grey hair over an issue, that nobody seems to be able to help me with, not even the technician who installed the entire thing (you will know more why).
I purchased a kit including the DS-KV8113-WME1(B), DS-KH6320 and a PoE switch.
My gate setup consists of a sliding motorized gate and a regular swing gate (not motorized). On the swing gate I have installed a Electric Bolt Lock.
I will call the devices as follows from here on:
DS-KV8113-WME1(B) - Outdoor Station
DS-KH6320 - Indoor Station
Sliding Motorized Gate - Gate
Regular Swing Gate with Electric Bolt Lock - Door
My plan was to establish a solution with following scenarios:
Result of the work is:
We have accopmlished scenario number 1 and 2, but not scenario 3. In order to assign tags to the Door with the Electric Bolt Lock, it has to show up as an Access Point in the IVMS. It isn't! The technician says he has no idea how to make the Electric Bolt Lock show as an Access Point, because my setup is not what he would call a standard solution, so I am basically on my own here.
As it appears right now, both our black and white tags open the sliding gate, regardless if we are on foot or on a vehicle. It is managable, to make it work by an app, but given that I have seen this work on several YouTube videoes, I would really like to use the functionality the product has available. I am thinking MAYBE it has to do with the connections coming from the Electric Bolt Lock to the Outdoor Station's "Lock" terminal. But I don't want to mess everything up, and pay the technician again to fix it.
Anybody has an idea?
I am attaching some pictures to get an idea of the external setup.
I hope somebody can help!
Best regards
Nissar
- A visitor rings on the Outdoor Station, the Indoor Station rings and depending on the type of visitor (vehicle or on foot) I would unlock the Gate for a vehicle (Key Icon 1 on the Indoor Station screen) or the Door or visitor on foot (Key Icon 2 on the Indoor Station screen).
- If there is a delay of 20 seconds with Indoor Station not openning, I want my mobile phone to ring (through the Hik-Connect App on iOS) where I would be able to unlock either Gate or Door
- Using the 4 access tags (2 black and 2 white). One black and white for me and one black and one white for my wife. I want the black tags to open the Gate and the white ones to open the Door.
- Outdoor Station is connected to my LAN network and powered by PoE through its LAN port in the back that is connected to the PoE switch delivered with the kit. The "Lock" port has connections going to both the Electric Bolt Lock (a black and red wire) and the Gate Motor. The "Alarm In", "RS485" and "Power" terminals of the Door Station are not used.
- Indoor Station is connected to my LAN network and powered by PoE through its LAN port in the back that is connected to the PoE switch delivered with the kit.
- The Gate Motor that is powered by 230V power has following modifications made:
- The motor's 230V current is used to feed 12V DC current to the Electric Bolt Lock with a help of an adapter
- An aftermarket IO device has been connected to the Gate Motor as well (in the empty space available). This IO device has connections coming from both the Electric Bolt Lock and the Outdoor Station. NOTE: The IO device (is a IoT device) that allows for the gate and the lock to be controlled through Google Home as well (completely independent of the HIKVISION setup)
Best regards
Nissar
