Ghosting on "use-ip Purschased"
It's a process of ruling out the weak link / problem area.
It could be PC/processing issues - is it the same when you view on a direct connected monitor?
Networking issues; Is the camera wired to the NVR? NVR wired to the router? PC wired to the router?
Camera to NVR.
NVR to playback device.
Is it a HikVision Camera?
What model please?
How many cameras do you have connected?
At what resolution & frame rate please?
Does live viewing look OK?
Hikvision DS-2CD2355FWD-I 5MP Turret Network Camera
just 1 camera (above)
live view is fine
Frame rate 20fps
res 2560x1920
it seems to be worse if i flick through the hours of the day once or twice.
Does your NVR/firmware allow you to check your HDDs?
As live view seems OK, and a single camera should not be too demanding for the NVR, I'm wondering if there's an issue with your hard drive.
