Hi, I'm new to this forum nice to meet you all
I was looking for help in purchasing the correct equipment to add a additional camera to my current set up. I have a I.T background so I thought I'd give it a go myself.
Currently I have a Hikvision DS-7204HGHI-F1 which I belive is a 4 channel DVR. The DVR has no more room to add any additional cameras to it. The DVR is also in a separate location to the router. I belive that I can add additional 5 network cameras to the system.
As my dvr is in a remote location and only has one rj45 leading to it and all the camera cables are best run from the location of the DVR. I was thinking of purchasing "Tenda TEF1105P-4-63W 4-Port 100Mbps PoE CCTV Switch 250m Extended Transmission" to suplly the DVR with Internet and the power the additional POE camera "Hikvision HiWatch IP Camera PoE 4MP Network Dome Vandalproof IR30 IP67 IPC-D140"
So the rj45 leading to the DVRs location will be pluged into the switch then from the switch I'll have another rj45 connecting to the DVR to supply Internet and also from the switch I'll have another rj45 cable running to the cameras location to supply power and Internet. Have I got this right?
Would I need any specific type of rj45 cable for the poe cam? Also connecting the poe switch to the DVR with a normal cat5 rj45 will that be OK also?
If you have any other solution or a easier work around please feel free to advise.
Thank you.
Regards
Tek
I was looking for help in purchasing the correct equipment to add a additional camera to my current set up. I have a I.T background so I thought I'd give it a go myself. Currently I have a Hikvision DS-7204HGHI-F1 which I belive is a 4 channel DVR. The DVR has no more room to add any additional cameras to it. The DVR is also in a separate location to the router. I belive that I can add additional 5 network cameras to the system.
Thank you.
Regards
Tek
