Hik-Connect Hik-Connect Event Playback showing alarm triggering
alexdel
I would like to help me if it’s possible.
Is there any way that Hik Connect app can show me during alarm playback what actually trigger alarm (for example with a green box as I have seen)? Because I have a lot of false alarms and I would like to know what triggers the smart event alert.
The area that covers is to big and when I playback the alarm video i cannot find out what triggers the alarm.
Thank you
Hi @alexdel
I'm not aware of a way to see the trigger box overlays in Hik-Connect unfortunately.
You will need to log into the NVR and use the playback menu to see these in a web browser or on iVMS-4200 - make sure that you have "rules" enabled in the Local menu though.
You may need to use IE mode to access the Local menu:
Hi @alexdel
Hi and thank you for your answer.
Can you help me in a couple of things?
Where I have to go to enable the “trigger box”?
First of all on ivms 4200 as also from my NVR menu.
My NVR is the 7732nxi.
Also do I have to do it for every camera that is on my NVR or is a general setting that applies to all of them?
Thank you
On iVMS-4200, you need to go to System Configuration>Image and make sure that both VCA Rule and Overlay Rules on Captured Picture are turned on:
When viewing on the NVR's local interface, you should see a toolbar appear when you hover over the camera streams in live view and playback - you just need to click on the Show / Hide VCA Info button on this:
Thank you.
So if I enable them from NVR this doesn’t mean that I will see the green box from ivms or web browser? I will have to enable them separately from anywhere I watch? Is that right?
No worries :)
Yes, that's right, you'll need to enable them separately on each interface.
If you are using a web browser, then you will need to use Internet Explorer initially to enable the rules.
When you connect to the NVR in IE you should see a Local menu under Configuration - this is where you enable the rules:
No worries :)
Thank you for your help.
So is there any way to have this green boxes on Hik-Connect too or not?
No worries :)
Actually I have not have a local option when I log in from web browser
