O OndrejL Member Messages 11 Points 1 Feb 20, 2019 #1 Hi, I have camera DS-2cd2085fwd-I, newest firmware 5.5.81. I am using Internet explorer 11. Problem is, that I can't change resolution or protocol to H265 anybody has a suggestion?
Phil Administrator Staff member Messages 5,195 Points 113 Feb 20, 2019 #2 The newest firmware for that camera is actually V5.5.82: DOWNLOAD EU PORTAL Are you sure that you are using Internet Explorer: Not Edge:
O OndrejL Member Messages 11 Points 1 Feb 21, 2019 Thread starter #3 ofcourse i am using IE. version 11.316. 7763.0 version of camera firware: 5.5.82 181211 Attachments ie.PNG 21.6 KB · Views: 598 ver.PNG 20.2 KB · Views: 611
Phil Administrator Staff member Messages 5,195 Points 113 Feb 21, 2019 #4 I can see that you are now running V5.5.82, are you still having a problems changing resolution or selecting a CODEC?
O OndrejL Member Messages 11 Points 1 Feb 21, 2019 Thread starter #5 BOTH, I change setting, and after refresh is back to previews settings
Phil Administrator Staff member Messages 5,195 Points 113 Feb 21, 2019 #6 What Windows version are you running please?
Phil Administrator Staff member Messages 5,195 Points 113 Feb 21, 2019 #8 Try Ctrl +F5 to refresh your browser when on the settings page before making and saving changes? Clear your cookies and history? Try running IE as an administrator? Run Internet Explorer as an administrator
O OndrejL Member Messages 11 Points 1 Feb 21, 2019 Thread starter #9 Thank you, CTRL + F5 didn't work, BUT "Run as administrator" helps. So I think that that was problem. Thanks Ondrej
O OndrejL Member Messages 11 Points 1 Feb 21, 2019 Thread starter #10 SORRY but nothing helps. After refresh I have old setting back
Phil Administrator Staff member Messages 5,195 Points 113 Feb 21, 2019 #11 Can you please upload a screenshot of a problem page? (you can just paste an image into the forum)
O OndrejL Member Messages 11 Points 1 Feb 21, 2019 Thread starter #12 config page before and after Attachments config.PNG 144.1 KB · Views: 1,052 config2.PNG 131.4 KB · Views: 896
Phil Administrator Staff member Messages 5,195 Points 113 Feb 21, 2019 #13 Is your camera perhaps connected to an NVR that cannot work with those higher settings? Are other changes that you make being saved OK?
O OndrejL Member Messages 11 Points 1 Feb 21, 2019 Thread starter #14 NVR is able to work with 4K. Sometimes it save setting correctly, most of times not
Calvinder Member Messages 19 Points 3 Nov 23, 2020 #15 I just had the same problem on one of my cameras. I noticed if I powered down the NVR , made the changes then powered it up again the settings stuck.
