Hi everyone,
I’ve just purchased a smart intercom that needs to be installed about 280 meters from the house, and I also need both an external and internal keypad for opening the driveway gate. I'm using a Hikvision UTP Cat 5e copper cable, but the signal is quite weak: the intercom turns on and powers the keypads correctly, but when I try to use it, the video often doesn’t appear, and the audio is delayed or unstable.
I tested everything with a 2-meter cable, and in that case, the system works perfectly, including control through iVMS. However, before laying down the 270 meters of LAN cable, I want to make sure the system will work as expected, as I don’t want to waste the spool. As a backup, I’ve also purchased a fiber optic cable, but I’d prefer to start with LAN. I’m not sure who to contact for splicing the fiber, and I’d like to avoid using a media converter at the gate due to potential issues like rain, condensation, and other environmental factors that could affect its functionality.
Does anyone have experience or suggestions for a similar installation? Thanks a lot in advance!
video
Watch Video WhatsApp 2024-10-09 ore 09.05.03_99048650 | Streamable
video
