Lock Screen Password
With System Config > Basic Info > Lock Screen Password set to off, the previous version would still require the pattern or password to be entered following a reboot when exiting the live view. This is resolved in this version (reported first in the other thread)
Playback Timeline Human Motion Markers
The markers for motion detection were missing in both local playback UI and Hik-Connect in version 5.04.020_241106. This was patched and fixed in 5.04.020_250113 (available on UK portal). That fix carries over into 5.04.050 thankfully.
Normal Playback - Human Vehicle Filter plus Play Strategy
1 - Human and Vehicle filter are enabled by default. No change there.
2 - Selecting Normal Playback > Settings (gear wheel) > Skip Normal Video on is temporary. For any setting on the Play Stategy fly out menu, the settings are only maintained while the Playback tab remains open on the local UI toolbar; once closed they revert to the default settings.
I've been told that the above is intentional and I'm not a fan of this change. Previously (prior to 5.04.020) selecting normal playback would have the Human/Vehicle filter icons deselected. By having Play Strategy > Skip Normal Video turned on, playback would always start at 00:00 on the selected day. The Human and/or Vehicle filter icons in the lower left could then be used as a one click toggle enabling you to skip between alerts but revert to full timeline playback if something of interest was detected. To get that same functionality now you have to:
- turn on Skip Normal video
- leave the Playback tab open in the toolbar
- each time you change camera deselect both Human and Vehicle filters
- manually move the timeline back to 00:00
I can't imagine a valid reason for that change.
Normal Playback - Playback Speed
The playback speed can only be adjusted during normal playback when the Human and Vehicle filters are deselected. The icons are missing to adjust speed and the options are greyed out in Play Strategy.
Normal Playback/Event Playback - Lower 'Actions' Toolbar
In normal or event playback moving the mouse pointer above the timeline causes the transparent actions toolbar to be revealed. That toolbar contains actions for Capture, Clip, Digital Zoom, Tag, Lock, Audio on. However, using the Smart Search in Normal Playback or More > Dual VCA > Motion, Intrusion, Line search in Normal or Event Playback will prevent that toolbar from displaying. If you need to use any of those functions you will have to exit out of the search first. Unfortunately that means that to continue on you'll need to start the search and draw the area or line from scratch.
Intercom/Doorbell Camera
Previously it wasn't possible to add a door station to the NVR. You can now add the doorbell camera as an Access Control Device without needing to use RTSP.
In version 4 UI you could add IoT alarms. That enabled you to configure an alarm for when the outdoor station was called. I cannot find any way of doing that in this version. In Event Center > Event Configuration there is no option for IoT alarms as there was in V4 and nothing for Access Control Event. Maybe I'm missing something but I've searched everywhere.... In Event Search > Event Type 'Access Control Event' is an available search type. I used to use this search to show every time someone had called on the KV6113 outdoor station and could configure linkage actions for the call button being pushed. That doesn't seem to be possible :-(
