No more connections allowed on this device issue?
Geordie564
Centurion!
The "No more connections allowed on this device" issue with new 8mp Colorvu cameras and I series NVR, does anyone know when Hikvision are going to sort this out? It's been a while now.
I suspect the long-term solution is newer better NVRs with greater bandwidth capability.
No sight of those yet :(
In the short term, I think that all you can do is make changes that reduce the bandwidth e.g.
Reduce your frames per second.
Use the most efficient CODEC (h.265+).
As a last resort use a lower camera resolution setting.
What NVR do you use? And version of FW?
Easiest solution is to restart your NVR so that NVR cancel all of previous "connections".
I'm not sure whether what NVR you have but I noticed a new patch firmware in the portal this morning for the I Series called 'HC Playback issue (exceeds max user) fix'. It does say importantly that it's not compatible with the 8 channel I series. It's here:
