Hello,
I'm experiencing an issue with two DS-2CD2021G1-I(W) IP cameras. Both cameras are connected to a gigabit ethernet switch, which is linked to my modem. Each camera is powered by a 12V 2A power adapter. I monitor the cameras using the Hik-Connect mobile app. The cameras are using the latest firmware (Firmware_V5.7.21_240422).
The problem I'm facing is random reboots of the cameras. The frequency varies—sometimes there's only one reboot within 24 hours, while other times there could be 4-5 reboots. Importantly, they do not go offline simultaneously, but both typically reboot at least once on the same day.
Given that both cameras exhibit this rebooting behavior, I doubt that they are defective. What could be causing this issue? I would appreciate any insights or suggestions you might have.
Thank you!
Thank you!
