N nightmoon Member Messages 7 Points 1 Jun 30, 2019 #1 Dear all, I have bought a new NVR with 4 IP Camera 4 MP last week. I left all the settings for default, but the resolution is not so good. What is the recommended FPS and Bitrate ? What is the relation between FPS and Bitrate please?
Phil Administrator Staff member Messages 5,190 Points 113 Jul 1, 2019 #2 If you use their h.265+ CODEC you shouldn't encounter limits / problems: Hikvision's h.265+ CODEC Perhaps share a screenshot of your current settings?
D dalydesign Active Member Messages 45 Points 8 Jul 5, 2019 #3 Here's some recommended bitrates for each frame rate: https://us.hikvision.com/sites/default/files/tb/tb_bit_rate_chart_120115us_0.pdf
D David Drewitt Member Messages 14 Points 3 Jul 5, 2019 #4 dalydesign said: Here's some recommended bitrates for each frame rate: https://us.hikvision.com/sites/default/files/tb/tb_bit_rate_chart_120115us_0.pdf Click to expand... Hi That is a great chart. Do you have H264 and H265 format as well that you can post? Dave
