I have DVR iDS-7204HUHI-K1/4S(B) running V4.26.011, Build 201109 with 2 IP cameras. I did have analogue but since upgraded over time.
My issue is I can’t seem to playback from certain days from the DVR? Either directly on the console or via the web portal.
BUT I can playback from the hik-connect app?
The reason I want to playback on the DVR is so I can speed up the footage which I normally do?
So I go to the DVR and playback then select the 14th Jan and it says no file found? Some days have like a little blue triangle in the corner but others don’t including the 14th?
I go to the 14th on the hik-connect app but no way of speeding the footage up?
I will attach some pictures.
