I have just upgraded to a 7608NXI-I2/8P/S and also a 2CD2387G2-LSU/SL and having a small issue with Live View over Wi-Fi.
Setup is as follows:
ASUS AC86U Router (Running RMerlin)
CAT6 cabling (Router > 1000Mbps Port Switch > NVR). This is all tested for full 1000Mbps speed as I transfer stuff to my NAS.
Hik-Connect App (iOS App Latest Version), added online device via Wi-Fi
1000Mbps Full Duplex
Latest Firmware on NVR (4.61.000 220507) & IP Camera (5.7.3 220216)
Static IP Address on NVR
CloudFare DNS
Output Bandwidth
35686kbps / 256.00Mbps
Input Bandwidth
34048kbps / 80.00Mbps
Picture Input Bandwidth
3072kbps
Picture Output Bandwidth
26214kbps
5x 2CD2342 running at 2688x1520 (all 10FPS, medium quality and H.264+, these work perfect)
1x 2CD2387G2 with the following settings:
8MP Camera
3840 x 2160 (8MP)
Variable Bitrate
Medium Video Quality
10FPS
Max Bitrate of 8192 Kbps
H.265+
When I view this on live view via Wi-Fi, it takes ages (10s+ to load) and often completely fails (error code 25 or network unstable, or half the live view goes green and freezes). When I get an event/notification, playback which is done via Hikvision server is pretty instant and responsive, it seems to load faster via Hik-Connect than Wi-Fi
I have tried disabling H.265+ and still the same, only thing is lowering resolution to 2688x1520 helps, but still takes a long time.
Any ideas?
EDIT: Looks like a potential issue with Stream Encryption and latest NVR firmware (4.51 apparently fixes it, and turning off Stream Encryption may too... decisions...)
CloudFare DNS
Output Bandwidth
Input Bandwidth
3072kbps
26214kbps
8MP Camera
3840 x 2160 (8MP)
Variable Bitrate
10FPS
H.265+
Any ideas?
