NVR DS-7608NI-Q1-8P firmware upgrade failed? [error OSCVG20-0x00100573]
Status
Not open for further replies.
amreltahan
I am trying to upgrade my NVR device, I am getting error OSCVG20-0x00100573
Current VersionV4.75.000 build 230620
Latest Version: V4.82.100 build 240606
As the automatic update via the App doesn't seem to be working it may be best to download the new firmware and update your NVR using a PC on the same network.
The firmware can be downloaded from Hikvision's product page for your NVR here (we believe yours is a (D) model):
Our instructions on how to update your firmware can be found here:
Thanks for feedback, I tried from SADP, Hik-connect, web interface and isgp.hik-connect.com all tries are failed. i am going to try to connect USB with updates to the NVR and try from device again
Hello. I have the same problem. Were you able to solve it? Do you have any idea how to do it? I can't do it either. My model is ds-7604NI-Q1/4P.
Hello, all trials failed, i am going to reset the NVR device to factory defaults and re configure it again. Does any one know how to do HW reset? i need full reset.
Hello, all trials failed, i am going to rest the NVR device to factory defaults and re configure it again. Does any one know how to do HW rest? i need full rest.
I understand somewhere through the menu or web interface. If you manage to overcome the problem, please write. I will also write on my side if I solve this problem.
Hello Enge56, finally i did the firmware updates through USB. i works, but i have other issues if anyone can help. Whenever i restart the NVR i have to re-configure the events and select send email for each camera. the other issue is one camera keep disconnecting to make it work i have to disable PoE channel then restart the NVR then enable PoE channel and restart the NVR again, this keep happening every day. any idea how to resolve.
Thread continues here:
Status
