Problem with Ax Pro alarm firmware update.
Halixman
My alarm wants to update to the latest version 1.3.0 241129. The problem is that it is stuck at 0%.
In addition, the current version displayed, 1.3.0 241115 IS NOT the one that the panel currently has. According to the website, the version installed is 1.2.9 build 231207.
Now I can't log in through the android app. It says that the device has no connection. The sim card does not detect it and the wifi is failing.
Where can I get the 1.3.0 build 241129 update? Apparently Hikvision does not update its firmware list on the web and you cannot manually download that build.
I was able to solve the problem. I had to create an account on Hik-Partner and register as Support. From my alarm settings I had to give it access to that account as "remote administrator". From Hik-Partner I could see the firmwares, download them and install them manually.
Now, the error I have that started everything was that the SIM card is not detected. The Wifi is also failing.
I had the same problem when upgrading to version 1.3. 0 build 241115. I searched and downloaded firmware 1.2.9 on hik partner pro and downgraded manually from pc browser, it works fine now but it says sim card has been removed all the time. Now the funny thing is that in system settings it says i have version 1.2.9 but when updating it tells me that i currently have version 1.3.0 build 241115 but that it needs to be updated to build 241129 but, like you, it doesn't go past 0%. Hope hik can soon release a version that fixes all this.
I have good news for you. I was able to solve the problem that the Sim card was not detected. What I did was disconnect the power and let the battery drain all day until it shuts down.
The next day I turned the power back on and apparently that reset everything. As soon as I connected it, the system sent me an alert via SMS. Now the device is updated to version 241129 (the latest) and the Sim card works perfectly.
same sim error after updation...hik connect app shows icon to update even after updating..and most frustrating is their is no silent alarm option for smoke detector after update. I can't make everyone panic by siren for false alarms.
Thanks for the advice, I did the same thing of letting the battery drain but when I connected it, it didn't update to the latest version, nor did it eliminate the SIM error. Maybe because I downgraded previously.
Maybe my only way to fix it would be to update to the latest version manually, But I can't find firmware build 241129 online.
If you still have your HikParnerPro account, you can manually download the update. That was the way I did it. Download the HikPartner phone app, log in, and there you can see your device with a red arrow pointing up. This indicates that an update is available. Don't update it from there. There is another tab that says FIRMWARES or something like that. There will be a link to download it manually. You copy that link and open it from a PC. I remember it is update 1.3 build 241115. After that you can automatically update to the latest 241129.
By the way, if you cannot see your device from the Hik Partner Pro app, it is because you must authorize the PartnerPro account from the HikConnect user application.
To me, the latest version available to download at HikPartner Pro is 1.2.9, the same I downgrade manually. Does the newest one appear to you? 1.3.0 build 241205?
I just realized that our devices are not the same model. That's why the updates are different. Mine is DS-PWA64 and yours is DS-PWA48.
I understand that the DS-PWA64 and the DS-PWA96 share the same firmware, but not the 48. An update just came out for my device, 1.3 build 241205.
I just did a search for your model and there is an update 1.4.6 build 240627 for you.
It's confusing though, because the build number is supposed to be the release date. It says 1.4 build 240627, but version 1.3 says build 241129. I would recommend that you download 1.4 and try it.
https://www.hikvision.com/es-co/pro...Intrusion-Alarm-Panel/ax-pro/ds-pwa48-kit-wb/
HI Guys,
I have the control panel DS-PWA64-L-WE with the firmware v1.3.0 build 25.01.21. It's nice that finally you can add up to 16 cameras to the Ax PRo but there is so many buggs.... it's terrible to have it...so many false alarms on cameras in comparision to the previous firmware....I have the intrusion and the cross line event on, and unfortunatelly the "motion detection" I neeed to turn off bacuse even the "notified surv. centre" is off the Ax PRO still sending the notifications to the Hik connect...
1. smart search on people - work's in 20%, it's not relable anymore
2. smart search on vehicles - work's even worst, maybe 5%
3. the basic event motion detection cannnot be "on" anymore bacuse is sending the notification every time when the movement appears ("notified surv. centre" is off)
4. Ax pro is randomly sending the notifications on Hi-connect with the Alarms (there is no description what alarm has been trigered), for egzample in short video I can see that the alarm was triggered by human which is far far outside the set perimeters of intrusion/cross line which doesn't make any sense. It's not that every time this is happening it's just randomly 20-30 times a day I receive this kind of notifications. When this alarm is being triggered the cameras will not turn the light or sound alarm (that's how they have been set on line crossing) // I use mix of DS-2CD2346G2-ISU/SL and DS-2CD2347G2-LSU/SL
5. on Ax pro I have two areas - front cameras and back cameras. If I only have the back area disarmed and I would go to the back of my house I would not receive the notification on hik-connect but the cameras light strobe/sounds will turn on...(?!) but if I would disarmed both areas than finally the back would be trully disarmed...
6. the camera DS-2DE3A400BW-DE/W stop being compatible with the AX PRO. Now when added to the AX PRO will send the notification of alarm to hik-connect (not sound/light) every time when only one Area on AX PRO is on. To not receive the notification I need to disarmed all areas on AX PRO. I already contacted the Hikvision and they informed me that I have a problem and the camera it's not on the list of cameras dedicated for AX PRO. Well...before was working fine and I did not have this kind of issue with it, so I ask them what they are expecting me to do with this camera ? It wasn't cheap +£200...I'm still waiting for their replay...
Is it just me having the whole alarm system in mess or there is more of us ? It is so not reliable anymore that I needed to turn off all notifications...in that case what's the purpose of this system ?! Thanks for your feedback
HI Guys,
This is not related to AX PRO firmware. Whatever camera detects its up to camera not AX PRO. It is just passing an event to alarm panel
Good day All
I am having problems with my AX Pro, updating. So the story is as follows. I bought the system and it came in a Hikvision box, but the system never worked very well. After investigation it appears it was a local security company that imported them with there own software. I am now trying to upgrade the firmware. The system tells me it is up to date, when I try upgrading with a pin it tells me it is not compatible. Will it be possible for one of you to download me the latest firmware file and send it to me.
