Remove audio from existing recording Hikvision?
stvn
Is there anyway to remove the audio from existing recordings. The company I work for had some internal misunderstandings, the installed CCTV was supposed to be without audio recording, even though I was told otherwise. Now I need to find a way that if someone downloads footage from a DVR, there shouldn't be any audio. I have already disabled the audio so that the new footage won't have any but the old footage remains with audio.
Hi @stvn
I don't believe there is any way to remove the audio from old recordings within the NVR settings.
If you need to remove audio from any old recordings I think the only way to do it would be to download it and then run it through a converter software (like the tool built-in to the Hikvision Windows VSPlayer) and convert it to a video file without audio.
Upvote 1
Once the settings have been altered so that audio is not recorded, it would be easiest to simply initialise the hard disk in the DVR and start afresh.
Upvote 1
