IVMS 4500 and Remote Config
jjmsau
NVR: DS-7608NI-I2 / 8P with Firmware V4.1.67 build 181106
IVMS 4500: v.4.7.2
Until recently, I was able to remotely configure (the limited!) elements of the NVR available through IVMS 4500.
- I can see all live camera vision whether on the LAN or away from home - so that tells me my FritzBox router is configured correctly.
- When on the LAN, I can connect to "remotely" configure the NVR via IVMS 4500.
- When away from the LAN, as from the last few weeks, I cannot contact (via IVMS 4500) to remotely configure the NVR.
From what I can tell, the ports are correctly forwarded on my router and UPnP is enabled.
Any thoughts? Seemed to start after upgrading NVR to V4.1.67 (build 181106).
Sorry, yours is the first report of this issue via iVMS-4500.
Most people now use HikConnect (App & portal).
Maybe the newest firmware does limit some access via the iVMS-4500 App.
I don't know.
We'll keep an eye/ear open for further reports.
Thanks - I've attempted HikConnect but without success. Cannot add my NVR, I receive the following error message when attempting to add my serial number:
"The device is offline. No search result is found.:
Take a look at this Post for clues please:
Hikvision serial numbers for HikConnect
If that doesn't help, please paste a screenshot of your error message here.
