Problem with camera resolution?
sterg
hello , i have a DS-7216HQHI-K1/A ,
the problem is that in some cameras it doesnt me show to set the max resolution to full hp 1080p only in wd1 960x576 ( the cameras support full HD)
I am using cat 5e cable and i have try with pulsar and hikvision baluns , also i have try another psu
Hi @sterg
What are the camera models that you can't set to 1080p?
Hi @sterg
the datasheet for your DVR says this about the supported resolution - "1080P(non-real-time) / 720P / VGA / WD1 / 4CIF / CIF"
We don't have much experience with analog systems but I wonder if "1080P(non-real-time)" means the recorder won't support true 2MP/1080p cameras at full resolution.
Maybe someone else on the forum who has used similar analog recorders can provide a more detailed explanation.
