Why is my 'live' view so bad?
BigAl
Looking at my system via IE, the images are out of focus, some camera's take what seems like ages to load.
I start with a screen divided by 9, the main camera, a PTZ displays very badly in live view via the front end interface (IE), yet when I go into 'Configuration', 'Camera Management' and then over to the far right and 'connect' directly, the images are pin sharp.
This has only happened since I upgraded the front end IE display.
As you can see in the image attached. the top half is the camera direct, the bottom half is through the IE interface.
And I have also noticed in Live IE view just selecting one camera, the time stalls, then jumps, then stalls, then jumps etc.
Hi @BigAl
Usually when viewing multiple cameras when logged into an NVR using a browser the cameras will stream in the lower sub-stream resolution. If you set the camera split to just one camera and then manually switch the camera to main-stream (this can be done either by clicking the symbol marked with a '2' next to the camera in the live view device list or by clicking the same icon at the bottom right of the live view).
Hi @BigAl
Thanks Dan, but this problem seems to have only appeared since the new IE interface.
I run 5 cameras off this NVR, 3 PTZ's and 2 static. 2 of the PTZ's have their own PoE power supply.
I have rebooted the system back to Factory Default about 5 times and I think initially it is OK, but then when I change the settings to UK settings, like Time, BST/GMT, date format etc I notice this problem reoccurs.
I'll reboot is again later or tomorrow and I'll note every change I make and see if I can work out what causes it.
Where would the upgraded IE interface have come from, was it within the upgrade of the NVR firmware?
Maybe I can downgrade it back to an earlier version, and see if I'm back to normal.
My NVR is a DS-7608NI-I2 / 8P with V4.51.025 build 210927 Firmware.
The main PTZ is a DS-2DF8236i-AELW with V5.5.2 build 180723 Firmware.
I suppose the upside of this is that it is the system on my house, so I do not have a customer breathing down my neck, and I can spend my own time trying to solve the problem.
The annoying thing is, it use to be very good, like for the last 4 - 5 years.
It must be the IE Interface or the settings attached too, as I wrote, the camera's are perfect direct and through my Android with Hik-Connect.
Thank you for taking the time to reply.
