AX PRO DS-KV6113-WPE1(C) and AX Pro compatible?
Wardl895
Hello all, I noticed the DS-KV6113-WPE1(C) had a built in (rfid reader I think it's called)
Is this compatible with AX Pro system?
Would be great if it was, e.g. Swiping tag on tag reader not only allows entry but also disarms the alarm system.
Hopefully someone can shed light...
Rich.
That's a great question, I was thinking the same.
I tried adding the doorbell as an AX Pro device but it didn't work.
Can the admins get in touch with Hikvision and suggest this worthwhile feature.
Hi @Wardl895 @Murfy92
We've checked with Hikvision support and they said this:
"No, it cannot do that. The AX PRO tag cannot be used to swipe the door station."
Unfortunately, this is not a feature currently supported by the AX Pro & Intercom products.
Absolutely so much potential to merge both... Door access... Alarm system...
Thank you for enquiring however, greatly appreciated.
