- Messages
- 3,263
- Points
- 113
Hik-Connect Alarm Enable Disable Issues
In 4.63.000 (with Hik-Connect 5.1.x) there was an issue with the event notification enable/disable function (the bell icon in the app). The button appeared to work displaying a message that notifications were enabled/disabled but it had no effect and notifications were always enabled.
In 4.63.000 (with Hik-Connect 5.2.x) it improved a bit. The new areas setup gives 3 options Arm, Arm Silently, Disarm:
- Arm - Enable events and push notifications and audible alarm/strobe light
- Arm Silently - Enable events but no push notifications and audible alarm/strobe light disabled
- Disarm - No events or push notifications and audible alarm/strobe light disabled
For each area Arm, Armed Silently, Disarmed were correctly labelled on each camera. Arm and Disarm worked correctly, however Arm Silently did not work with push notifications still received regardless.
In yesterdays release 4.63.005. The problem is not resolved:
For each area Arm, Armed Silently were correctly labelled on each camera ('Armed', 'Silenced). Disarmed is incorrectly labelled 'Silenced'. Arm and Disarm worked correctly, however Arm Silently did not work with push notifications still received regardless.
So nothing has changed with regard to the incorrect operation except that a Disarmed area is now incorrectly labeled Silenced - it's actually worse
